how to add curve onto existing IMM brush curve
hi guys, i am creating a necklace with bead shaped IMM brush and i want to be able to add onto the curve i’ve drawn because i can’t draw out it all out in one line. is there a way to do this?
Yes, you can add to the curve:
  1. Place your cursor over the end you want to add to so that you see the green line pointing upwards. Don’t click.
  2. Move the cursor a little away from the green line in the direction you want to go. As soon as a red line appears start click+dragging out the new curve.
got it! thanks :slight_smile:
