How much detail can a normal map bring to a base mesh?
I want to create a short animation. I was going to create the base in Max then do the normal/bump maps in Zbrush. My question is how detailed does that base mesh have to be? Could I make a very simple base then do all the musculature in Zbrush or would that make it flat?
Provided that the map is made correctly, an incredible amount, but the detail can be offset by the lack of detail of the mesh.
