How do you use sphere brush?
I have been trying to get spherebrush to work but I don’t understand how to.
If I try and use it on a tool, it says I have to exit the “edit / transformation” mode. So I click “switch”. Then I can paint on my object, but it appears that it has switched to 2d mode. There’s no way to switch back to edit mode.
I actually don’t know what mode I am in once this happens. The only thing I can do at this point is redraw my tool and press ctrl+N which deletes the previous thing (what is a tool called in the canvas once it’s no longer even a thing???)
Same with drawing the spherebrush stuff on an empty canvas. It looks cool but I cannot figure out how to get it to stay.
there sphere brush is a 2.5D brush. It isn’t used for working on 3D meshes…unless you’re using projection master.
If you want to add a sphere or string of spheres you should use the sphere insert brush. Pixologic has a great set of tutorials on the insert brushes. A must have for workflow.
