How do you correctly use transparency?
I’m not able to use the Transparency by clicking the “Transp” I tried some ways but so far the object is only normal in color, with solid color and no transparency. I would love to use this function. How do you correctly use transparency, to see over the object?
<img src=“http://www.zbrushcentral.com/pixo/atn.gif”>
Try turning off and on ghost.
Thanks for the answer! yes I desactive the Ghost, and keep the Transp Actived, but still the same…
But how everybody use this transp? Is just inserting a mesh in edit mode and clicking in Transp button? Just this? Or I’m doing someting wrong?
Because I don’t know what is the correctly uses u know.
transparency works with subtools. Try appending in some other object and see if that helps.
If not, post up an image so we can better see what you’re trying to accomplish.
Is fixed! Actually was a little advanced to undertand I have to agree. That’s happen because most of people start using zbrush thinking that he is the same as a 3d graphic program and is a little bit dfferent in you interface.
What I was triyng were make the transparent to edit in photo cordenates but for it you have to make the exacly zbrush way. And not the other, …something. Thanks!
