How do you apply projection to Boolean subtract on sub tools menu?
When I use boolean to add one mesh to the other using sub tools it produces a mesh that is less then perfect, not to worry just apply projection and you’ll have a pretty decent mesh. My problem is that when I subtract a mesh from the other and I apply projection it doesn’t work the same way, it always gives me back a model without the subtracted projection. How can you apply projection in such cases? Can you?
Thanks
