How do u export a sphere 3d face in obj
Once you have shaped a face out of 3d sphere, how do you get it to export as a true poly model in obj format?
Thanks
Patrick
If you are using the demo version then I don’t think you can export *.obj.
In the full version there is an export button in the “Tool palette” - this will export the object out of zbrush.Also in the tool/inventory palette there are options for export (eg. dxf or obj)
Hope this helps ?
Wow I just came to say I got it to work, at first I could only export as psd. Do you know the ansewer to the other question?
Thanks
Patrick :smiley:
For Export Psd
Menu Document/ Export :slight_smile:
For the true model
The explanation taken above is a true model exportation :slight_smile:
And for the facett : Disable Smooth Horizontal And Vertical if you want see the facettes :slight_smile:
(Menu Tool/Modifiers/Sh,Sv)
Pilou
