I want to add mesh as guides for gluing multiple 3D prints together.
The model has to be split to fit the printers build volume. It’s hard to keep the parts aligned while the glue sets.
I can build guides using the topology brush, with a small amount of thickness, thus building a tab which will overhang the adjacent subtool. If I put a few tabs around the circumference, the two printed parts will align. After the glue sets, I can sand off the tabs.
This only works if the tabs sit on the surface. If they have depth into the model, the overhang won’t slide over the second part. It also causes problems when I make a shell.
I can’t figure out how to just add the mesh to the surface. The brush adds an equal amount to the front and rear face (the inside and the outside of the model) so the tabs intrude on the adjoining part.
Backface masking doesn’t work.
Any ideas, or an alternate workflow?
Thanks in advance!
