How do I turn off the auto-collapse on the menu pulldowns
I’m trying to turn off the menu auto-collapse. e.g. when i’m adjusting settings iin Z-Plugin -> Multi Displacement 3: I change MapSizeAdjust the menu then disappears. I want it to stay there so I can change other values…
I have searched the forum but to no avail. Its likely i’m using the wrong name for it and so i cant find anything. :frowning:
Remember doing it in ZB2 but I cant find the option on 3.1.
Thanks in advance…
You can turn off auto collapse here: Preferences -> Interface -> “auto collapse.” If auto collapse is highlighted in orange, give it a click then "ctrl+shift+I to store the new configuration.
Cheers
Cheers Filament, but thats the Auto Collapse for palette’s. I’m needing the auto-collapse for the menu’s :confused:
Ok, now that I re-read your post I get what you are after. Try this:
You will of course end up with the entire Zplug menu, but this way the Displacement menu will remain open until you close it. Hope this is of help to you.
Cheers
Seems simple enough, and yet I never thought of it :cry:
that’ll do nicely!
cheers man :smiley:
