How do I tile a texture in zbrush 4 r2?
Plain and simple I want tile a checkerboard pattern higher so I can check how well uv master works.
thx!
A quick way would be to load the checker texture as a pattern under Noise Maker. Set it to use UVs, and then adjust the scale (strength of 0, use color blend instead)
