How do I save a new Lazy Mouse default?
I’ve changed the ‘Lazy Mouse’ setting for the Standard brush and saved it to ‘Startup’ -> ‘BrushPresets’, but everytime I restart ZB4 then my Lazy Mouse setting has been reset to it’s default value “1”.
How do I save this setting until next startup? I think I’ve read somewhere that the setting should be saved with each brush, but I can’t find that info anymore. Hope someone can help. Thanks!
/ tennet
I believe Lazymouse settings default every time you start ZBrush. You can record a macro with the settings you want and have it run automatically at startup. See my posthere.
Thanks, that works fine! I tried to hide the Lightbox menu (,) while recording the macro, but Lightbox is still loaded when restarting ZB? Do you know how to turn it off by default also? Thanks again!
If your on a PC, just add the following line to your DefaultZScript.txt file to have Lightbox off at startup.
[If,1,[IPress,Preferences:Lightbox:Lightbox]]
If your on a Mac, see this post.
Edit: I’m sure the Lightbox button will be fixed in ZBrush 4R2.
