Like in the video demo? I turn custom UI on, and then?
(I can drag the entire plugin palette into right palette, but I only want uv master, and also decimation master.)
When you have Preferences > Custom UI > Enable Customize turned on you can CTRL + Click drag most user interface items to new positions around the canvas. This does not work for all user interface items as some of them only exist while a certain type of tool is selected. For example, the Tool > Adaptive Skin > Density slider is only active while you have a zsphere Tool/Subtool selected.
When you are finished moving user interface items arround turn off Enable Customize and save your configuration with Preferences > Config > Store Config (CTRL + SHIFT + I).
All of this and more is described by Pixologic’s Online ZBrush documentation.
Yes… I read that… and I cannot drag the new uv master tool over to the right palette, like you see in the first tutorial video. Hence my question.
Instead to tinker with it, I just dropped the whole plugin palette over there temporarily
The left and right sidebars are for entire palettes not individual buttons. In the tutorial video the ZPlugin palette which contains UV Master, is placed in the right sidebar.
You can create your own palette where you can then drag the UV Master buttons into. That user created palette could be dragged to the right sidebar and stored.
Don’t think it is possible to just drag these individually to the right palette.
Richard
Ah, ok… then I’m doing it properly then. It looked from that first tutorial video, that he just moved just uv master over. I’ll have to watch it closer, to see what he actually did.
I had my interface all nice n neat before the 3.5xx series, and have been so busy lerning the new tools, that I haven’t reorganised my interface like I had before.
EDIT:
Yeah… he just dragged the whole plugin palette to the top of the right pane.
