How do I make my X symmetry line up again?
I was modeling my character and now my X symmetry is off center. How do I get it to go back to center so I can use symmetry again?
go to transforms menu and click S.pivot. or take the level one model into another 3d modeling app and center it manually and re-import… Local sym button may help as well
Press Shift F and check your topology, you may have moved one side too much when symmetry turned off.
If thats the case then you could mask the half of your sculpt you want to keep (at the lowest subdivision level or you might have to check between levels for best results), CHOOSE LEVEL FIRST THEN MASK DONT MOVE BETWEEN LEVELS WITH MASK. Then go to the “Deformation” menu and select “SMART RESYM” and choose the axis you want. If you get some noise but your satisfied with the fix, turn on symmetry and smooth the normals by pressing and holding SHIFT, begin to smooth the surface gently, then while keeping your pen on the tablet, let go of SHIFT.
