Since you are new, here’s another method if you are bringing in your base meshes instead of creating them in ZBrush.
Make sure that in your 3D host app (Maya, Max, etc) that your objects have all of their transforms frozen and the pivot zeroed out to the world 0,0,0. This will ensure that all your objects are correctly scaled in ZBrush and if you export things from ZBrush they will align properly when reimported to the host. It will also make sure that your maps are generated properly based on object scale.
I didn’t know this when I started years ago and it drove me nuts. Just make sure the scale, translation and rotation have all been frozen. In Maya you use Modify > Freeze Transforms and then Modify > Reset Transforms. Also check to make sure you delete the history on your meshes so there are no extraneous nodes that could mess with OBJ creation.
If you need to maintain these things in your host app, just make a new scene and freeze all the stuff for exporting.
