How do I go about changing the shadow color?
Under BPR shadow there is no longer a color picker. What is the best way to change the shadow color?
You can change the shadow color by using one of the BPR Filters. Use Filter>Color and BlendMode>Color and set the Shadow (Modulate Strength by Shadow) slider to 1. Also, you may need to set the Render>BPR Shadow>F Strength slider to about .5 to show the color in the floor shadow.
Alternatively you can use the Shadow pass from the Render passes to apply a color to the shadow layer in Photoshop or similar program.
Thank you!
