Hello,
I am on a MacBook Pro 15 in. I cannot get to the controls past Solo in ZBrush. Could someone suggest how I might be able to?
Also, is it not possible to set up the scroll wheel to zoom in ZBrush?
Thank you,
Cris
Hello,
Thank you,
Cris
Smaller UI configuration http://www.zbrushcentral.com/showthread.php?94752-Useful-small-ZScripts-and-Macros-for-ZBrush-4.0&p=734962&viewfull=1#post734962
There is only one button below the ‘Solo’ button and that is ‘Expose’ which is in the ‘Transform’ menu anyway. You will find that you will rarely use it. If you absolutly have to have it visible, then you can ‘Enable Custom UI’ and Ctrl+Alt+drag it from the Transform menu to the left side where you have room.
You could also increase your monitor resolution to 1024 or higher on the vertical. If it will allow it.
