how do i get a refernce image into zbrush?
i have a picture of what i want my model to look like, and it is a pain to alt tab out to keep looking at it :stuck_out_tongue: is there a way to put an image into zbrush that i can look at all the time?
The “Image Plane” plug-in is the easiest method.
http://www.zbrushcentral.com/zbc/showthread.php?t=46396
Don’t know if you are on a Mac or if it works for a Mac?
You can also make sure your reference is the same dimensions as your document. Load your reference as a texture. Then on the texture pallet click fill layer.
