How do I customize for my laptop those icons below Ghost Transparency? Answered.
I do not have access on my laptop to the Solo Mode and Xpose View buttons along the right side of the workspace. Is there a way to move these so that I can see and have access to them on my laptop?
Thanks for any help with this.
Are you able to set your monitor at a higher resolution, at least temporarily? Set it higher, then run Zbrush and more of the interface should fit on your screen. From there, make a custom interface, and drag the buttons somewhere more accessible for you.
Alternately, there is a “button size” slider in Preferences>Interface that will let you squeeze more of them onto your screen, after a restart.
Solo and Xpose are both also available from the Transform menu.
Refer to your Zbrush documentation to see how to make a custom interface. The online docs are down, so i cant link you. Basically, click “enable customize” in preferences>config, ctrl-alt drag what you want where you want, store config, and save a copy of the ui for fast recall as well, in case of mishap.
Thanks Spyndel…will try that now. My resolution is already at it’s highest setting. I will try re-sizing buttons.
There’s a smaller UI config file here that you may find useful:
Useful-small-ZScripts-and-Macros-for-ZBrush-4.0
Thanks…that worked well.
