My symetry got wrong so im trying to do this. I thout there was a way to do this whit out cutting it in half.
Thanks.
If it’s only a few small things, try Tool > Deformation > ReSym or Smart ReSym? Otherwise best bet would be to cut the model down the line of sym. in max/maya/modo/blender or whatever and resym it in that.
Tools: Geometry: Mirror and Weld often does a great job making a mesh perfectly symmetrical. It transfers from right to left, so if you wanted the opposite, rotate the model 180’ first.
Thanks very much will try and let you know.
So long as the center line itself is still intact, you’ll find that Smart ReSym works perfectly. To use it to best effect:
- Go to level 1
- Mask the side that has the details you want to keep.
- Use Smart ReSym
- Go up a level and Smart ReSym
- Repeat step 4 until you’ve done the highest level.
- Unmask
All details from the good side will have been perfectly copied to the other.
