How can I set a smooth brush in Z brush to have the smoothing strength like Sculptris
Hi all, I have just started using 4R7 after using sculptriss a lot. I am trying to get the zbrush smoothing brush to behave like the smoothing brush in sculptriss.
Mainly it seems very weak, in sculptriss the smooth brush will smooth down for example; if you use the standard brush and make a raised stroke on a flat plane with the sculptriss smooth brush you can just about flatten the whole stroke down to the plane. In zbrush I have tried all settings, I think? with the smooth brush, but it will not be able to smooth down a whole stroke like this.
Any one have noticed this difference between the two programs, and or know how I might get the zbrush smooth brush to act like the sculptriss smooth brush?
Thanks
PS.
In playing with this some more I think it may have to do with sub division levels in zbrush. I noticed that with a model that has lower sub division levels you have more smoothing power at lower levels.
But I have taken a model that I was working on in zbrush that only had one lower sub-d. level and I felt the smoothing was really weak for what I was trying to do , even at the lower level, and I brought that into sculptriss and the smoothing power was so much stronger even at the higher dub-d level? So I am still wondering if I can do any thing like that in zbrush?
Have you tried the smooth stronger brush? Located under lightbox>brush>smooth
It’s just a more powerful smooth brush as the name implies and works well on higher sub-d models.
Thanks so much Mr. Spooky. I didn’t realize there were additional brushes in there. Yes that one does the trick
