Hi every one, am new in Zbrush. and so far the challeng is: How to render an object with a transparent background… any one please?
Simply use Alpha>Grab Doc and export the resulting Alpha. In Photoshop, use it to remove the background from your main render.
Even better, open the Render palette and turn on the Create Maps switch. Now do a BPR render. This gives the highest quality render of your model while it’s in Edit mode. After the render is complete you’ll see several maps in the Render palette. One of them is Mask and already has the levels adjusted to use for removing the background in Photoshop. (The Depth map is the same that you’d get using Alpha>Grab Doc, above.) Click the icon of any map you wish to export and you’ll get a save window.
Exactly… it worked :lol:
