how can I check the vertex points on model zbrush?
Also how do I make them equal on subtools? I’m trying to merge some subtools.
I’m not quite sure what you are asking. If subtools have the same number of subdivision levels then these will be preserved after merging. If you want to merge the actual topology - in other words connect the vertices - then you will need to use the topology tools after merging.
