How can i adjust one end of a already drawn curve (with curveBrush)
In this video ZClassroom Lesson - Curve Surface Brush at 2:20 he adjusts the end of the curve with “bend” turned off. All i can do with bend turned off is to move the whole curve. Is this a feature that is not in zbrush anymore (all the videos that i saw which show that possibility to adjust the curve like that are very old).
I guess there would be a lot of people interested in an answer to this.
Thanks in advance.
Have a nice day :slight_smile:
Since no one else has answered this, I’ll just verify that I can’t make it work either. I’ve never used that particular tool before, so I dont know if there’s a trick to it, or if it’s bugged.
Thanks for testing!
That is very sad that it seems to be removed as a feature. This is something that is actually really needed.
I find using the curveTools very annoying as they are.
Have a nice day.
If it’s truly not working now, it’s more likely a bug than a deliberate feature removal. If it’s something you’d llike to see fixed, make a support ticket and report the issue.
