How can i achieve this look??
Hi all.
Im trying to do my own tree with this look, but i dont know what types of brushes could i use to do those plannar woods and extrusions with “flat” look? I dont want rounded things
Any help?
Thanks! :slight_smile:
There’s a square alpha in the standard set - you could add with that and lazymouse and then smooth off the other end.
I’d probably mask the whole thing, mask rectangle with alt to unmask a bit you want to extrude, soften the mask a bit, then use mask rectangle again to sharpen it up on three sides, then use transpose with either move (w)or rotate and move to pull the geo out. Will that work for you?
The layer brush also pulls out a nice slab type thing but again you’d need to smooth it back into the trunk.
H polish, flatten, pinch, clip curve, trim curve and trim adaptive are also all great brushes for cleaning up.
Thanks a lot foxtrotzulumilkshake!
I will try your way and i will come here again if find some troubles. :slight_smile:
