Hotkeys broken
I seemed to have lost some hotkeys. Not sure how. But my [ ] for resizing my brush size has stopped working. When I open the program I test the brush size. I tap ] and it increases my brush size then I tap it again and it stops.
Using 3.5r3. Removed the polysphere from the startup zscript.
Also is there a way to setup a project folder so zbrush doesnt always go to its root folder tree? I’d like to be able to allocate a directory for it to use.
Visa 32bit
zbrush 3.5r3
I restored my default Zscript startup file and it fixed the brush scale hotkey issue. How can I remove the polysphere at the startup without my hotkeys being destroyed?
For the hotkeys, see tip #29 here:
http://www.pixologic.com/docs/index.php/Tips_and_Tricks
For changing startup stuff see here:
http://www.zbrushcentral.com/showthread.php?t=79709
You can’t get ZBrush to always open in a designated folder. But creating a shortcut and putting it in the ZBrush folder speeds up navigation. (The shortcut will also appear in LightBox.)
