Hotkey weirdness – how to remove assignment? (answered)
I’d like to set my often used brushes to the number hotkeys, but at the moment Replay Last stroke is set to the hotkey “1”. If I change that hotkey to, say, Shift+1, ZB now remembers both hotkeys for this command rather than replacing the original… and the hotkey “2” also seems to perform this same command.
Is there any way I can remove this hotkey assignment altogether so that I can use it for a brush instead?
Thanks
Just assign ‘1’ to the brush - that should then overwrite the original.
