Hotkey for standard brush doesn't work?
I have a strange issue with 4r4, I took my past preferences with my hotkeys, and for an unknown reason I am unable to use the 1 hotkey to select my brush.
The hotkey is assigned but using it doesn’t select my brush, and because it is the standard brush it’s quite annoying because I use it everytime.
Does zbrush has a preference converter because it is quite annoying to redo your preferences every new version.
The interface keep changing, some brush I was using disapeared in the default interface and so from my custom interface, and my hotkey doesn’t work.
Even if I really enjoy Zbrush that’s something that keep bugging me having to keep your preferences is really important.
EDIT: Even better, it doesn’t seems to be linked to my hotkey but to my standard brush, no matter what hotkey I choose I’m unable to select it.
I found what was causing this issue, it is linked to the new “popup” feature, you can assign hotkey while taking popup window into account.
Still have to replace my past UI to get my interface back but now I’m assigning hotkey from the UI it seems to work.
Thanks
side note.
they moved where UI and hotkeys and such are stored so you shouldn’t have to update them every time a new version is released from now on…at least that’s the talk around the water cooler…also in the docs for this release as well :slight_smile:
