how can I assign a hotkey to the Material List so that the material selector comes up ? Similar to what F1,F2 etc are doing for Tools, Strokes etc.
I can’t for the life of me remember how I did it before.
jens
jens
F6 is supposed to be the shortcut for Materials, but I think it is buggy in Z4R2. If you press F6, all it does is select the Flat Color material. If you press F5 for Texture palette then, immediately after, press F6, it works fine.
Ah that would explain that. I assumed I assigned the FlatColor by mistake to F6 and was trying to get the material list back. Hmm. But if you got that as well I assume there’s no way to make this work.
I don’t think you can get it to work, because if you try to assign a different key, it only does the same thing. (select Flat color).
For some reason the hotkey will work if your cursor is off the document canvas area.
