I have Zbrush 4 at work and this isn’t a problem but for some reason my home copy is giving me problems (both running windows XP). How can I fix this issue? Should I re-install? All the other hotkeys seem to be working fine.
You can re-assign the hotkeys by Ctrl+Alt+clicking on the buttons. You’ll find them in the ZPlugin>Misc Utilities menu. Remember to store the hotkeys by pressing Preferences>Hotkeys>Store.
New in ZBrush 4, you can now set the increment through the Brush Increment slider in the ZPlugin>Misc Utilities menu. When the brush size is less than 10 the size is always changed by increments of 1, whatever the slider setting.
Thanks.
I just noticed that I have to not touch my wacom wheel until I open a subtool. Then the brush resize will work fine. If I try to resize right after opening the program, it won’t work at all unless I restart and open a subtool. Weird.
Re-assigning the hotkeys should solve that.
Yay! That worked. Thanks a lot!
