Hotkey "a" for "Adaptive skin" AND "Unified skin" (solved)
Hi! I am using ZB4 and I cannot use the “a” hotkey anymore to preview adaptive skin in “zsphere mode” and Unified skin in “Zsketch mode”. I can only assign the “a” hotkey to preview one or the other… if I try to add the same hotkey to Unified skin then it just overwrites it.
Please help!
/ tennet
You shouldn’t assign the A hotkey to either, it is assigned by default. If you open your StartupHotkeys.txt file in a text editor you can take out the lines that assign the A hotkey. Then they should work OK. You’ll find the file in the ZStartup/Hotkeys folder.
Thanks Marcus! Now it’s working again. :slight_smile:
/ tennet
