I mean, for me to get a normal map, I lower each sub tool to it’s lowest division and hit “create normal map”.
The end result is a normal map for each tool.
How do I make a single map, with all the normal maps combined?
The UVs are laid out to not overlap.
What I do, is put all subtools to the lowest subdivision, then merge them.
I’ve exported this tool as an OBJ, and I re-import it then append it to the bottom of the subtools.
Where do I go from here?
Am I supposed to merge the high res subtools into one object?
Or map I stuck generating a map for each, then merging them in photoshop?
