Can one of you really smart people out there make a plug-in that hollow’s out models for 3D printing?
It would be ideal if you could…
1- type in the desired shell thickness. If areas would be too thin for it to work (like fingrs, teeth, etc) it would ignore that area.
2- you could control the density of the inner mesh as to not increase poly count for services that have poly count limits.
3- If a model needs a hole in it to remove support material you could mask out the desired area and thickness/size.
4- you could check your models wall thickness before exporting them for printing. You could just type in the size you are think of exporting the model at and it would tell you thicknesses or any other print related errors.
5- you could use this with both decimated models or non-decimated models.
6- The inner shell would have reversed normals.
I think thats it, This would save us all A LOT OF MONEY in printing and A LOT OF WORK in other programs.
Who ever makes this first will be the win the smartest person trophy- which
will hopefully be hollow.
