I don’t know if it comes from my computer or not, but if I have an hotkey including shift key and I want to toggle a command by holding shift and pressing the associated key (e.g: Shift+L, holding shift and hiting L two times), the second time shift is not taken into account.
I have to release shift and redo the Shift+Key combination.
There is a way to just hold shift and press the second key without having to release shift and repress it?
And an other question, when I right clic and select a menu, (brush or subtool) the menu disappear depending on the area of my right clic, it seems that while triggering the menu it doesn’t appear right under my cursor so it disappear instantly.
I have to right click on the lower left part of the screen to be sure that my menu will be under my cursor and won’t disappear.
There is a way to prevent that?
And the last one, how can I assign an hotkey to the color picker aswel as the color chooser (the palette that open when you click on your Main color swatch)?
