Hi, Ive been practicing Zbrush for some time and Ive learned a lot of things, but just recently, when I was about to render a final piece of mine I noticed: How can I get high resolution renders in like wallpapers size inside Zbrush? Is there anyway? I`ve seen a lot o cool works in extreme high resolution on this forum but i wonder if they had to transfer the sculpting to another program to be able to get that size of image…
If someone could help me I appreciate.
In ‘Document’ menu, turn ‘Pro’ off and make your document size 3000 x 4000 (for example) then click ‘Resize’ button. Answer Yes to the dialog that pops up.
On the right shelf, use the ‘Zoom’ button (Zoom Document) to zoom your document out until you see the whole thing. You will see the borders when you have zoomed out enough.
Draw the Tool on the canvas to fit inside of the document and arrange as you wish.
Do a BPR render then go to ‘Document’ menu and click ‘Export’ button to save your image.
Tip: You will get the best looking images if you render a bit bigger size than what you need, then resize the document smaller in your 2D app.
Thanks for the reference Doug Jones, I had search previously on the forum about the subject but i couldnt find anything about it. looks like I didnt search enough ^^.
And thanks for the detailed answer zber2 !!
No problem Stark!
