high resolution image ?
Is there a way to get a high resolution image your model to use for a printed ad out of Zbrush that does not take a lot of enhancement in another program? I’m not familiar with the Zbrush as many of you so please be descriptive as possible.
thanks B
Increase the document size to twice needed. Should be okay when scaled down.
its still not clear enough, any other tips for a clear image?
In the Document menu…
  1. Turn ‘Pro’ off and change Width and Height to whatever you want, (maximum is 8192 x 8192) then click ‘Resize’ button and answer yes to the popup dialog.
  2. Using the ‘Zoom’ button (Zoom Document) on the right shelf, zoom out until you see your entire document. (ZBrush does not automatically zoom your document when you change its size). Now draw your model to fit within the document and adjust to your taste.
  3. You will get the best quality image using BPR render. If you want a floor shadow, you will have to turn on the ‘Floor’ button on the right shelf. As far as all the settings for lighting and shadows associated with BPR go, you will have to do your own research as it is too extensive a discussion for here.
edit: When done rendering, click Document > Export then chose your ‘save as type’ at which point you might recieve some more options.
