high-resolution image into Photoshop (answered)
Hi guys,
I am trying to export a high-resolution image out of Zbrush into Photoshop for a poster I want to print. So far I can export psd’s etc. but the images are all low res. Is there a solution?
Cheers,
Vadim
ZBrush only deals in actual pixels for image dimensions, so you will need to create a document of the size you need in the Document palette, then export a render of that. You would then open in Photoshop and change the dpi without resampling the image (so the pixel dimensions remain the same).
For example, if your poster is 8.5 x 11 inches at 300 dpi you would need a ZBrush document of 2550 x 3300 pixels.
Hi Marcus,
Thanks for the quick reply, that should definitely help. You’re awesome!
Cheers,
V
