High/low Poly
Is there any tutorials where explains how to do a model from high to low poly and opposite? I have searched every where but i can’t find anything about this.
Or at least some advice/tips how to do this?
first of all this post has to be in the [other quetions and truble shooting] but i will anser anyway
you can use subdivisions scrol bar but if it ant going as low as you want you can use[unconstruc subdivisions]
but im not sure what you want to do so if you give a detal post of what you are trying to do it would be alot more easy for me to tell you
Sorry then, couldn’t found that topic, hope some of the mods will move this thread there.
Sorry that my question made you confused.
Well everywhere i read that, when you make a high poly model, you then concert it to low poly mesh so can be used in-game. That’s i want to know how to do it.
Displacement maps are what you’re looking for I think. I don’t know enough about the topic to help you along with it, but search around for displacement and normal maps and that should point you in the right direction.
the best way to do this is to do retopogy
and i think on www.pixologic.com thay have a plugin for lowering polys by keeping the detal hope this helps
