hiding part for modeling
working on this mesh in maya while i test in zbrush need to hide separate pieces for better modeling. thanks for the time.
Use Ctrl+shift and drag to hide, if you release shift you invert that.
That way you can seperate the Polys you want, convert them into a Polygroup (Tool/Polygroup(Group Visible). Once you got your Polygroups you can seperate your parts with a simple Ctrl+Shift+click
Hope that helps
thanks alot for the tip cheers:)
