Hide parts of a retopo or activate a shading
Hi friends of ZBrush,
Hope this is the right forum for my question.
I’m searching for a solution, but i can’t find it.
i make my first retopo in ZBrush and it’s very confused to connecting the edges. The mirrored site is permanent visible and inteference with the view of the current range.
My question: can i shade the retopo-polys (so it has no transperency) or can i hide the mnirrored site of this?
Thanks for reading.
Hope, you understand my problem bad english
Greetings
jovomo
Make these changes in:
Preferences > Draw menu
Front Opacity 0.95
Back Opacity 0.01
Thank you for your answer, zber2.
It helps a little bit :slight_smile:
I’m hopefully, Pixologic is working on the retopo and make it easier and userfriendly.
Greetings
jovomo
Yes, I also hope they fix it in next update.
You can also try the Appended ZSphere Method to retopologize.
Yes, it works!
Thank you, zber2 for the link :slight_smile:
I have seen this site for a long time ago, but my skills in ZBrush at this point are very poor.
Greetings
jovomo
Your welcome!
Another thing that makes the retopo lines really visible if your using the Appended ZSphere Method is using the ‘BumpViewerMaterial’ in the Standard Materials palette when you retopologize.
