Hi Rez SubTools - Next Step
Looking for advice on the next step.
6 sub Tools all detailed and ready for…?
I would like to project all the hi res detail, but I’m not understanding which low res mesh to use. (I have tried the Z project and Project all with bad results)
Here is what I’ve tried (all sub tools are at highest Sub D level)
:red_circle: Merge Visible - :cry:
:red_circle: ReMesh All - :cry:
:small_orange_diamond: Unified Skin res 512 (This worked the best but did not merge all tools)
Here is the Goal:
:large_orange_diamond: 1 Animation ready mesh with poly groups
:large_orange_diamond: 1 4096 UV and Normal Map
I don’t want to try the Projct all brush, or Project All till the Mesh look right.
sounds like you need to bake your highres meshes down to a lower version.
“any” 3D app can do this.
I personally use xNormal to bake maps down.
I’m not concerned with maps right now, just getting a good mesh. I think the next step might be retopology over all the subtools?
So what is the workflow when something like this happens?
I have started to mask areas where the Projected details are to strong.
But I’m not sure how to fix the mesh when the polypaint and material don’t project correctly.
example: maybe 90% of the eye projects, but then parts will have no deformation or material.
Update
