I try since many days to generate an HiRes alpha from “GrabDoc” feature in alpha-menu.
I managed to divide the 3D-Object in many parts and to fit these to document-size at a 8K x 8K document (max. in ZB).
My Goal is to put these images together and compose an 32Kx32K Image
After importing .tiffs in Photoshop the neigbour-parts (images) have different grayscale values even though they had the same depth value in ZB !!!
It means ZBrush transfer the same geometry in different grayscale resultes (alphas).
Is there a way to achieve an even distributed garyscale value in all images?
Many Thanks in advance
Zbrush Object consisting of 2 identical subtools :
The 2 exported Alphas from ZB :
