hi quority print out
Hi All
I am new zbrush user.
Is there anyway that I can do print out image of zbrush created object like print ad quority.
I exported document. opened in photoshop. It was not high res enough.
Does anybody have the answer?
thanks
ZBrush exports screen resolution, which is 72 dpi. If you want higher resolution, create your image at a larger canvas size (you can go as high as 8,000 pixels) and then after exporting from ZBrush you can use Photoshop or another image editor to resample for the dpi you want.
“quority” :slight_smile: I like your sense of humour.
