help!!!!!!!
i painted my project and now i want it in a difrent program called blender and i was wondering how i could export the painting i did on it to like i picture that i could use as a textture in the other program
its realy simple.i think you are a zbrush starter.read the zbrush user manual.and there are m any tutorials in internet.
there is aoption under texture submenu in tools menu,in it there is an options for from polypaint.it will give you texture and you can save it outside.you can now use it in other softwares like maya,blender etc…
for full learning,you can search in tutorial forum in this site.
if you are using zbrush3.1 there is small different,you should first make a blank texture and now use texture from polypaint underrrrrrrrr(actualy i forgot that menu but you can search in all menus you can found some buttons like AUV ,PUV etc).
…hopes i helps you
