help with zbrush modeling
hi i want to ask you if i cant edit models like in 3ds max i mean editing vertex points
Hello,
It is possible to move and edit one vertex of your zbrush model at a time. With limited control. Simply size your brush way down to a very small size. This way it does not influence any other points near the one you are moving. This is one method to move the vertex in a low poly model.
okey thanks
