help with symmetry
something funky is going on with symmetry and i’m in need of help fixing it.
I went to try out the radial setting on a plane.
i set up the tool fine, i think. i forget how to make the plane double-sided.
when i turn on symmetry, the drawing points are vertical, although i selected x symmetry. and when i attempted to draw, after turning radial symmetry on i could not see anything happening, though yes i was in edit and draw mode…
i loaded a cube and turned on x symmetry without the radial turned on. the cursor still shows vertical as if i had y symmetry turned on.
any clues into what i’m doing wrong, would be most helpful…
lawd, is there a newbie forum here?
Hey there,
some screengrabs might help, but if you want to use radial symmetry on a plane 3D or a polymesh plane 3D actually you need to set the radial symmetry to the Z axis :wink: which is logical as that is the axis pointing towards you.
Hope that helps … a bit!
