Help with starting up
I need help starting up, I’ve found various tutorials on the forums and on the home page but a lot of them seem to be about creating an actual project. So I’m wondering if anyone has tutorials on how to make base meshes or simple objects that can be used to help me create my own models with Zbrush?(On account of I haven’t got the money to buy any other programs like 3ds max)
Thanks, Tanreet
Hi Tanreet, have you checked out the online documentation?
http://www.pixologic.com/docs/index.php/TOC
It´s the best you read it top-down.:slight_smile:
You´ll find for example the “Getting started tutorials”.
And I recommend to read the Zsphere section.
That´ll definitely help you to create Base Meshes.
(There are several tutorials -> for example “Building a Basic Humanoid”)
Hope that helps.
Thanks so much! I’m sure this will help me start off.
see the button at the top of the screen that says “Zclassroom”.
If you like videos that are short and to the point. Go there…everything you’ll need to know is there.
