I’m putting together a reel and need some help on the output settings. I am doing turntable moves in ZB, and will cut and edit in windows movie maker. The goal is to have a decent high quality file for web site and also something I can zip and email. I’ve done a lot of testing but not really sure what to set everything at.
What record frame rate to use?
What playback frame rate to use?
Is MPEG-4 a good compression type to use?
What is the (limit data rate to) setting do?
Is there a way to get rid of the Zbrush logo I tried all the settings and it wont go away?
