Help With Creating A Image Plane Reference Texure
Hi
I am in need of help in creating a image plane Texture on a x axis Image Plane Template. After I import an image plane tool I try to import and assign a texture that I made in PS with the x axis IP as a template. When I import the texture it wont go on the IP X axis tool geometry ? Am I missing a step? Any Ideas? I am creating an IP to use as a 3d reference model from Maya that is a Man of form
Thanks for you help!
Tim C
Just Ran into this problem myself and was getting pretty furious that something so simple took me so long to figure out
all you need to do is go to the texture section in your tool panel once you have created your Xplane then simple click on the texture section (should be an empty grey box) then choose your texture
Hope it works for you too
