Hi first of all i have some anoying things going on
- After a while, my brush (Zadd) and sometimes (Zsub) feature will hang.I mean even if i switch with the hotkey ALT it stays in Zadd mode,I then have to manually change in the top menu.It works again after i restart zbrush.
This is annoying and I can’t figure out what’s wrong!
2.I have set the doc size to 874/862 and in the Lightpox option under preferences, I unchecked Open at Launch.I Shift+Ctrl+I to save the master config.However, still it will open in half that size and with Lightbox at startup.When i push the button Init Zbrush it works.However, do i have to Init zbrush always?I mean I changed the master config file, but it doesn’t open with the settings I changed.
3.After a while, my Mesh disappears from the canvas if i rotate,zoom or pan.
It happens always after a while in higher subdev…
Why?
Im running Windows 7 x64 pro
Zbrush 4
/Robert
