Help. Transpose Master Problem: Zscript error?
Help, I get a Zscript error after Transpose master merges the subtools. see image:
Anyone has experience this same problem?
How can I solve it.
Thanks
Which version of ZBrush is this?
actually the problem was I followed someones post on plugin directories which i got in this forum. as follows:
Your ZBrush3\ZStartup\ZPlugs folder contains:
  1. TransposeMaster.zsc - the plugin file
  2. ZFileUtils.dll - the DLL file
  3. TPoseMasterData - the plugin folder (which contains the file TPoseMasterData_folder.txt)
It turns out that it was not all correct.
the dll file should be in the TPose folder.
all solved. sorry i pressed panic button too fast.
thanks to all concerned,
lesson learned.
Cheers.
