I have never been able to get the stencil to work, and I need it. When I click “Stencil On” it just flashes orange for a split second and goes right back off. it doesn’t turn on and the default stencil does not appear. What am I diong wrong? Thanks!
Nevermind I got it.
How did you fix it??? I’m having the same problem. Thanks!
Tanner J.
Once you have your alpha selected, you have to go up to the Alpha palette and press “Make St” (make stencil). Then you can change various settings from the Stencil palette. Use the space bar to activate the stencil control coin, to move it and size it, etc. Good luck!
Thanks for the help!
